Volt warnings with Asus AI suite
28 Aug 2014
i have done some messing about with AI suite. a month or 3 ago i used it to tune up my CPU i think it got as far as 106 or 105.x not sure but it was more than 104. that is the overclock. not the temps or anything.
i used the advice from this forum a few months previous to that and upped my clock to 103. few months later i saw the ai suite thing and thought "ill give it a try". it was ok might have caused a couple of blue screens after a few days of use so i moved it down to 103 and all seemed fine for ages.
the other day the missus had BSOD while i was at work she said "it said "google was going to harm my computer" and it went all blue". so when i got in that night thats when i changed it down to 103. just incase.
now i am getting Volts warnings. ie. V5 0.000. thats probably wrong. i will make note of it next time it comes up.
i am using an i7 2600 non k so that is pretty much the best i can do to OC.
i want to know what should i set the thing to to make it back to stock volts etc. i hit the OS defaults button but it doesnt change anything.
Leave the fsb alone. Your chip is not fully locked either you can overclock the turbo by 4 on the multi. Intel called it limited overclocking.
should i be touching any of the voltage things? and what should they be at stock? i have a feeling AI Suite has changed them and the default wont change them back.
