Voltage Damper
26 May 2007
Hey
Currently have my q6600 G0 at 3.6ghz on an asus p5k deluxe, fully stable. However ive not got the voltage damper enabled (massive vdrop/vdroop:eek:) If I do enable it and reconfigure my voltages. Will a see a drop in temps under load? Or will they be the same?
Thanks
You can either:
Stay at 3.6ghz, find the lowest stable voltage, if its lower than what is going through it at the moment then temps will be lower
or
Find the highest fsb speed for that voltage, you might be able to push the cpu further and shouldn't have any problems with temps if what they currently are are fine!
Well ive found the lowest voltage to keep it stable with voltage damper disabled... I know it helps with vdrop/vdroop. But if the processor needs a certain voltage underload its not going to help with that is it?
So if anything load temps would increase/stay the same?
Or am I barking up the wrong tree?
Open CPU-z, get IDLE and LOAD voltage.
Turn on voltage dampener and go back into windows.
Check IDLE and LOAD voltages again.
Work out the difference, go back into BIOS and drop the voltage by that difference. ie on my P5K board mine the voltage drop was something like 0.1v and now it is 0.08v. So I dropped the voltage from say 1.5v to 1.41v as they are both equal to 1.4v~ under load :)
