Voltage differences between gskill kits
5 Jul 2005
Edinburgh
Look at the 5400 kits: 4,4,4,8 for 1.8-2v or other 5400 kit of 3,4,3,8 @ 2-2.2v
6400 kits: hz: 4,4,4,12 @ 2-2.2v and ga: 3,4,3,8 @ 2.2-2.4v
and then the 8000 @ 4,4,4,4 @ 2.2-2.4v
Is there much difference between any of the 6400 and 8000 kits as i bet the hz will do 8000 speeds at those volts or 3,4,3,8 as well. Have so far got my hz stable at 475mhz @ 4,4,4,9 @ 2.2v.
Basically if the hz8000 is fine at 2.4v will the hz6400 be ok at those volts or is there actually a difference other than the labels?
