Morning all,
Hoping someone with a bit of car electrical knowledge might be able to help me here.
Basically, I've had a few moments when driving flat out ie down a slip road or something, and when the engine reaches high rpm (6k plus) I get a trio of warning lights for ABS DSC and TCS.
Did a code read and the error was 5d97 and 5df7, which equate to
Dynamic Stability Control (DSC) sensor. Voltage supply
And
5DF7 System voltage greater then 18 volts
At the same time most recent, there was a high load on the electrics, with heated seat, climate control, radio, lights and wipers on.
I've recently changed the voltage regulator as I thought that might be the problem. However on the way home yesterday I monitored the voltage all the way and had a constant 14v when driving, +-0.2v.
The car also reads the engine off voltage as 12.3v which I believe is on the low side? I've never had any issues with starting the car so the CCA is clearly not deteriorated severely, but perhaps the constant output could be?
The other consideration I had was a possible bad ground, does this sound likely?
Any help would be fantastic, and if any more tests can be done to further narrow down the culprit please let me know.
Edit: monitored the voltage on a drive this morning. Running engine to redline with HVA blower, lights and radio on and steady 14v.
Turn heated seats on and try again, spikes up to 18v.
So realistically, would this point to a bad battery/alternator? Can't see it being ground when it seems dependant on electrical load, unless it's a bad ground on heated seats?
And
