Voltage limit
2 Jan 2004
Kent
Hi all,
Memory as Sig- What would be the max voltage without causing any damage to memory-Having a few probs trying to runn at 444 12 1T,although it stats on memory that it is this.
I take it your RAM is this model
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
If so then your voltage should be set to 2.1v maybe +0.3v in bios.
BigRon said:
Hi all,
Again, just let us know what exactly which model your RAM is. If it is the 2.1 Volt stuff it just depends on how much cooling you put on and how brave you are ;)
