- 12 Dec 2009
Hi, this is my first post so please bare with me.
I bought the Velociraptor system at the start of December and have been experiencing constant crashes in games which I originally put down to the 5870 drivers being unstable seeing all the other posts about people having similar issues. I sometimes get the vertical lines fault but most of the time the system freezes playing a small loop of sound over and over and the only way to stop it is to press the reset button. The games I have experienced it in are MW2 and CSS source, however when it happens it can range from a couple of minutes into the game to a couple of hours in both games.
Anyway getting back to my question, tonight I had yet another crash and decided to run OCCT to ensure that the system is stable, however on starting to run the test I have noticed that the voltage on Core 2 of the CPU which should be at ~3.3V is staying at 0.19V and not moving even under full load.
I thought that this may have been a new issue, but after going back to look at the logged results from when I ran it after I received the system it appears that core 2 has always been at this voltage.
So I guess my question is, could this be what has been crashing my system all along (system is fine doing anything other than gaming, furmark, 3dmark etc)? Also what are the implications of this, do I have a duff CPU or is there a quick fix to make it work again?
Since the system is under warranty I will be contacting system support at overclockers tomorrow but would appreciate any suggestions/help that anyone can offer.
Many Thanks
Ant
Many Thanks
Ant
