- 23 Aug 2010
Hi,
I am a bit of a noob at this overclocking game so it might be a lame question
If you look at this screenie I did, the Vcore voltage in Touch bios is 1.32v but in CPU-Z the core voltage is 1.056v and in Core Temp the VID is 1.3761v are these the same? (voltages is set to auto) I am only trying a small overclock of 4.2ghz on a i2500k at the moment until I work out how to change the voltages safely. The screenie is shown running prime95.
cheers
Will
cheers
Will
