voltage question on r 5 2600x
11 Sep 2011
so finally got around to oc'ing my 2600x using an aio cooler ive get to 4.2ghz at 1.40v testing in cb r 15 i max out around 71.8°, idle it sits around 37-42. I know ryzen master states up to 1.5v is safe for these cpus but wondering if this is safe for long term use? when i was using the precision boost over drive the voltage would hit 1.485 so im still below this limit with a higher clock.
just wanting to make sure I'm not stressing it too much.
after a bit more messing ive managed to get it stable at 1.3v at 4.2ghz, seems all good :) sits at 61° under full load for an hour of prime 95 in a blend test. so will test it longer when i get the chance
