Voltage Question
22 Aug 2004
Have the following spec
Intel Quad Core 2.66
NVidia GEforce 8800 GTX
Creative Xfi Sound Card
2 GB Ram
Win XP
ASUS P5n32-e SLI Motherboard
Coolmaster Case
When I run the NVidia Monitor all the voltages are marked as Red and not the safe green, should I be worried, also ran the ASUS Probe software and heard a ton of alarms is this normal?
What power supply are you running and what are the voltages showing, possible screen shot.
Also double check with the BIOS, I would thought if they were to far out you would start getting problems like crashes and BSOD.
Upload with imageshack, take a screen shot, copy to paint and trim, save, upload to imageshack then copy the code to the forums.
voltages don't seem too high, maybe a little on the cpu side?
I wouldn't trust the nvidia monitor its not very good lol
CPU and memory voltages are fully normal, CPU infact little highish.
And rest are chipset/bus voltages and they're generally in that area.
