Hi all,
So I just got my 5950X and I’ve started ‘playing’. I heard the best way to check for the ‘safe’ 24/7 voltages is to turn on PBO, run prime and check for the min SV12 core voltage under load. Problem is, when I do that, I land with 1.168V. If I try to manual OC with this voltage the best I can get is around 4.4GHz (all core). Surely this CPU can handle more voltage without degradation? Thoughts? I should add this is under a custom loop so temperatures are more than fine to go higher.
Thanks,
Thanks,
