Hi Folks just a quick question on setting the voltage for my XMS2 RAM.
I believe my RAM needs 1.9V but the nearest options I have in my BIOS is 1.80v and 2.00v. What should I select and would using the 2.00v setting cause problems at all? I don't trust the 'Auto' setting and want to make sure I set it correctly. Many thanks for any advice you can give
