Voltages ok ?
23 Dec 2002
Shiny Shanghai
So since there doesn't seem to be a PSU section I thought I'd post here :)
Looking at my system voltages everything seems smoothly running...
But when you zoom into CPU, it's a bit wobbly....
Is that how it should look ??
I would imagine so. CPU voltages constantly change slightly when idle and if something like your antivirus started updating it may clock up slightly, needing more voltage.
Same possibly goes for load.
Moonpie, any idea why your ram temps are 1.68 volts? are you pushing those sticks hard? if so then its ok, but for stock that's high
I assume its because I got my system set to XMP and it pumped them up to 1600mhz and OC'd my CPU at the same time........ Or something. :D
Actually, I built a new PC last night, so it's kinda irrelevant now.
But thanks for all the replies anyway :)
It was an i3 something or other, so I guess that's why the volts were wobbling about. And now I know that's accepted behaviour for my new i5 too !! :D
