- 5 Aug 2006
- Kent, UK
I'm using an MSI P35 Neo2 FR with an E2200, and 2x 1GB GeIL ULL PC6400
In the BIOS (version 1.8 - the latest) i'm given loads of voltage options i've not seen before (just come from an Abit NF7-S v2.0 with an AMD Barton - old school i know).
I know the usual stuff: vCore, vRAM, NB v, but what is VTT FSB voltage, SB I/0 power, SB core power, and do i need to do much to them when overclocking?
I found this semi-useful info pack from MSI: http://www.msicomputer.com/msiforms2/maxP35.asp
which kind of explains what each setting does and recommended voltages to use, but i would like to hear any advice from anyone here too.
The reason I ask is that my RAM voltage is overly high regardless of what I set it too. In the BIOS i've set it to a range of voltages 1.95 - 2.10, but in Windows Speedfan always records the RAM v as much high (normally around 2.3+) which I think is a little high for this RAM (as well as unnecessary).
), and its not hot. warm, but not hot. might not mean much though as i think iwas running the CPU test (small FFTs) rather than a RAM test.
