- 18 Oct 2012
ok, so here's the story:
after having got a new 290x, and finally replaced my psu, decided to eliminate some of the bottleneck from the cpu with a bit of clocking. first time and all and i reckon i have the principle ok, but need a few pointers.
specs:
fx8150 [yes i know....]
990fx sabertooth [gen 1]
r9 290x reference [powercolour, not oc'd because of the heat]
wd black 1tb
alpenfohn k2 with a pair of corsair sp120's instead of vanilla fans
corsair ax860 psu
all stuffed in an air 540 case
so here's the story of how it went. i've been clocking just with multiplier and cpu voltage offset:
3.6-4.0ghz [18-20 multiplier] on stock voltage [1.2]
4.2 [21 multiplier] on +0.00625 voltage offset
all of these lasted 10 minutes on prime 95 blend [will be running a 24hr test once i'm happy with it because i need it 24/7 stable]
the issue i'm having, is at 4.4ghz, i'm going to +0.04735 voltage offset, this setup is stable for the 10min test, and cpuz is reading 1.356v
problem is, on the k2 temps are skyrocketing for that, 80 degrees for the vrm's and 71 degrees on the cpu.
now in terms of voltage input that doesn't seem to bad to me, but i was under the impression the k2 would be capable of keeping a lid on the temps up to circa 4.6 with 1.45 volts before i had to worry, despite the 8150 having the same thermal output as a small volcano.
so question is, bad cpu? bad cooler? or am i doing it wrong?
specs:
wd black 1tb
corsair ax860 psu
), at some point but cant afford it now so ill just have to live with it. at least thanks to mantle I can still play bf4
