Volume boost app for my new headphones?
28 Jan 2011
Hey guys,
got my new beats studio 3 headphones yesterday and they are decent cans..
only thing is on my iPad they don’t go too loud, is there any app etc. As a solution for this?
Always check the empiendence of headphones before you go plugging them in ipads and phones.If all headphones sound quiet then look for a pre amp app or music player. Loads on android, no idea on ios though.
Which app are you using? The Studios should be plenty loud enough to cause hearing loss.
none at the moment, using Spotify for my source.
It’s via Bluetooth :(
Crap ipad or crap headphones then mate. Way too many headphones have to meet regulations so idiots don't wear headphones loud and damage thier ears. Ergo they by default don't go all that loud. I always check or test before purchasing, although in covid times that's almost impossible.
Have you tried restarting the iPhone?
Updated iOS and the Headphones?
Make sure you set normalisation/volume to normal on Spotify.
Have you tried them on another device?
In OS X and iOS all the volume comes down to the operating system kernel and it controls the volume and any volume curves. So any app is simply using that.. so I’m not sure they’re worth it on iOS/OS X.
Think I need my ears cleaned :D
does go loud enough, just wishful thinking for them to go crazy loud, probably to avoid distortion etc..
