Volume?
11 Apr 2003
Notts
Hey all,
Just done a clean format of my PC, the only problem is my Volume controls do not work now, that is to say I can adjust them with the mouse, but if I use the buttons on my keyboard, or remote they do nothing.
The only way I can get them to react is by installing/reinnstalling the Logitech iTouch for my keyboard, but the remote is not Logitech and they worked fine before the format, and once I reboot stop working agian untill the next Reinstall of iTouch...
Help!
Thanks,
Jcb33.
