I have a friend who's just picked up a '98 reg S40 that continually flashes its indicators if he locks the car with the remote, is this indicating some kind of fault and if so, what?
Cheers.
my volvo only flahses the once when locked. This is the way it should be on the s40 too i think.
Do they work normally when its unlocked and while driving?
Seems it will likely be the alarm siren. Just found this. Theres a couple of threads on there about this, new siren seems to fix the problem. They're about £130 from Volvo or £30-40 second hand.
