how would a geartronic R be slower than a geartronic T5?Why? In geartronic version it would be slower, much heavier on fuel that T5 S40 and handle like a yacht on trailer.
either way, a manual is the way to go as their hideously uneconomical in manual form.
volvo quote 32mpg from the S40 T5, which is rubbish. the R is 26mpg apparently, although that's more likely to the be average from the T5 too. they're the same 5 cylinder lump, so the consumption won't differ all that much
regarding the handling, i can't comment as i've never driven an S60, but the S40 is hardly the best handling car in its class
That happens only in BMW six pot world. For starters the R is all wheel drive and has torque limiter to protect gear box, so it has considerable poke losses by design. In reality you are probably right - T5 will achieve 26 mpg, S60R will be lucky to see 20.volvo quote 32mpg from the S40 T5, which is rubbish. the R is 26mpg apparently, although that's more likely to the be average from the T5 too. they're the same 5 cylinder lump, so the consumption won't differ all that much
S40 is based on Focus platform, so, it is as close to decent handling as Volvo badge can offer.regarding the handling, i can't comment as i've never driven an S60, but the S40 is hardly the best handling car in its class
that appears to be the case for the geartronic, i apologiseS60R is 0.4 second slower than S40 T5 (or S60 T5 for that matter).
If you like the T5 then have a look at the D5. Very good engine too, and if fuel economy is on your mind then 40MPG at 80 cruise and 222hp (466 lb/ft torque) when chipped it does go well
Just my two pence tho.
