Voucher Code?
16 Jan 2007
England, UK
Hi,
I am going to be buying this graphics card Saphire ATI Radeon HD 3870 in a few days but £8 for shipping? where do you get "Voucher Code" so I could get a little knocked of the price as I am about £3 short.
PS - I have allmost built a PC it only needs a Graphics Card, Hard Disk and DVD Drive, If I try and boot without these would it send out a beep code or anything as when I try and boot the system fans come on but the CPU one does not and it does not even beep.
Thankyou for any advice
I think you will need to wait then until you have £3 more as those vouchers only go for special promotions or may be if you buy a lot. There was a 7.5% voucher not so long ago for a few people that completed a survey.
OK, Any idea about the PS part. Another site said its an Intel processor and it and the fan only starts when it reaches a certain temp any idea if its right?
It's a Intel Core 2 Quad Q6600
LOL your cpu fan should be on all the time unless you got water its that simple.Have u got the power to run all your pc.
Ha might have something to do with no hard drive.If not as i said cpu fan should always be on.
These are the items I have purchased upto now.
  1. Gigabyte GA-P35C-DS3R Socket 775 8 Channel Audio ATX Motherboard.
  2. Intel Core 2 Quad Q6600 G0 Stepping (2.4GHz 1066MHz) Socket 775 L2 8MB Cache (2x4MB (4MB per core pair) Retail Boxed Processor.
  3. Corsair 4GB Kit (2x2GB) DDR2 800MHz/PC2-6400 Memory C5(5-5-5-18).
  4. Antec Nine Hundred - Gaming Case with 200mm Top Fan - No PSU.
  5. Coolermaster eXtreme Power 650W PSU - ATX 12V V2.01 120mm Fan 20+4pin.
  6. Arctic Cooling AC-FRZ-7P Freezer 7 Pro Socket 775 Processor Cooler.
that's what i was about to say... and a CPU will shut off quick quick with no power to the fan... is there an OS on the hard drive? is there a bootable disc in the DVD drive?
Most modern boards by default give a bios "press F1 to continue" error if the cpu fan is not connected.
You can then turn this off in bios.
On the Asrock board I was running in the summer with a 2180 in it, the fan didn't kick in straight away, only span up if it warmed up.
