- 30 Oct 2002
- Inverness (UK)
Bit of a cryptic Subject, sorry...
We have a few remote sites that use standard BT Home Hubs and have 2~6 users on-site.
They are about to go through a domain migration, so in order to get their laptops onto the new domain we would need an always-on VPN setup.
Obviously software VPN's wouldn't work to change domain on the laptops.
Plus they are a 12 hour ferry + 6 hour drive away so getting them into the main office is not practical.
We could send DrayTeks out to site, configured for their BT Broadband and set up a VPN tunnel to the main office but it is reasonably high cost for the number of users.
Is there such a thing as a little box that would plug into the BT Router, then provide a VPN tunnel to the main office?
We then just set that as the default gateway for the laptops to the little box, remove / join to new domain.
Thanks
The other option is we leave their laptops on the old domain and just pick them up if they ever get to the main office... Not a neat solution though.
EDIT - Some sites have 1 user, so passthrough VPN wouldn't work for them :/
EDIT2 - Apparently there was a Linksys USBVPN1 - But can't really find these now - Not been made for many years.
May have to just get routers for everyone.
Thanks
