This may be a long one...
I currently have 3 networks:
1) Home network - Fritz!box 7530 router with a Synology DS218 NAS
2) Work network - Draytek 2862n
3) Parents’ network - TP Link Archer C7 with a Synology DS118j
I am currently backing up a PC at work to the NAS at home via Synology Drive Backup. I am trying to work out whether it would be better if the two networks were connected via a VPN, so I could use different backup software to backup to the NAS directly as it would appear as though it was on the same network. I am not sure if I can create a LAN-to-LAN network between these two routers however or whether it is worth setting up the VPN Server package on the NAS itself to link to.
I would like to create a similar link between the home network and parent’s network so that an Apple TV on the parents’ network can connect to the NAS on the home network. As an Apple TV cannot be a VPN client I think this would have to be done at router level, but again I am not sure whether this is possible with the hardware available?
Part of this is due to increased security and speed provided by a VPN connection over using Synology’s Quickconnect system. I have set up my iOS devices as VPN clients to remotely access the work network, so am aware of the basics around VPN connections but I am not sure as to how feasible the above connections would be - I have spent a good few hours searching for answers but this seems quite complex. I appreciate any help, although I get the feeling that without the same routers at all locations this is not going to work.
