My auntie and uncle have asked if I can setup 'a link' over the internet between our two networks so they can backup files (cloud based suggested) and also so I can RDP when they screw up. So I'm looking at ways of making a VPN.
Their network consists of a Sky Hub SR101 (IP 192.168.2.1)
My network uses an Asus RT-N16 running Tomato (192.168.1.1)
The ideal situation would be to configure a VPN between the two routers, which is not possible due to their Sky hub and they are reluctant to change this. They do however have a CCTV server running Windows 10 Pro that is always on, could this be setup to connect to my server/router and then share the VPN across the rest of their network so we can view shared folders from either sides, etc?
The other complication is they have setup on their Sky router a DDNS hostname for their CCTV, and I have a homeserver hostname setup on my side, that I'm worried would cause complications with routing.
I already have both my server (WHS2011) and Tomato router setup as VPN servers so I can connect when I'm away from home.
