- 18 Oct 2002
- Somerset
I am interested in what VPN options people use at work (or rahter out of work)
I have been asked to look into itand come back with options and costs,
At my previous place of work we had VPN software licensed for a number of users, and after that number several just had a windows dial in VPN set up.
Is using a standard windows connection a secure way of doing things?
If so why is there so many other options available?
Is dedicated software/Hardware a better way to go?
What about key generating USB sticks?
What do you use?
Thanks
Keith
What do you use?
Thanks
Keith
If you do go for openSSH then if you can filter the IPs allowed to access via your firewall(if your users have static IP addresses) also ensure that you have security settings on windows to enforce regular password changes and force people to use complex passwords > 8 chars in size(the bigger the better).
