Clarkey said:server at home, client at work...
[Sniper][Wolf] said:So even though my Router supports VPN Passthrough, i would to install VPN Server software on a server or machine?
Im guessing i have to pay for both the client/server software
oddjob62 said:VPN passthrough just means it recognises outgoing VPN traffic and supports it passing through. You still need something elso to be the VPN endpoint.
Buffalo2102 said:Try UltraVNC
I use it without problem and you can even do file transfers using it. Support is quite good too through the linked forums.
[Sniper][Wolf] said:Has anyone just used the windows based ones?
i.e setting up a VPN server on windows 2000 advanced server and using the vpn client on xp?
oddjob62 said:Yup.... i use them all the time.
[Sniper][Wolf] said:Will just use this then instead of installing third party software
Correct.[Sniper][Wolf] said:Isnt VNC a remote management tool?
attman said:easy innit? I've done it lots of times.......(unless I'm missing something)
[Sniper][Wolf] said:Is this possible using my windows XP machine at work and my Netgear DG834G, the router supports VPN Passthrough and VPN Termination.
Would i need to install a VPN Client on any of the client machines?
