Hi,
As the title says I have two computers at home and when I establish a VPN connection from one to the VPN server at the place I work everything is fine. When the second computer tries it can't connect.
Now I've checked my routers specs and it seems my router can only handle one tunnel at a time. The question is, will a router that can handle more than one tunnel be enough to make this work?
I've had some people say it would work and I've had some people say it wouldn't unless the tunnels were going to different VPN servers. Have tried searching around on Google but can't find an example exactly the same, or not one that I could understand the technical speak in anyway.
Someone from work said that I could create a single connection from the router itself instead of a connection from each computer, but I'm not sure if that makes sense/would work or how you would go about doing that.
Anyone have any knowledge on the subject?
Cheers,
-K
Cheers,
-K
