VPNs Again!
28 Jul 2008
Hi All,
Thanks for your help last time. Now heres my current problem.
Got a client with 3 sites who wants a VPN setting up between their offices in the I-O-W, Southampton, and Sweden.
They want a VPN link for phones in Sweden and those in Southampton. Apparently they are using Linksys routers.
Anyone got any experience with VPN'ing with sites in Sweden?
Don't you just love mopping up after people?
MTIA
Jon
Ok you got me!
Apparently "in Sweden they seem to do things a bit differently, there are no VPI, VCI, PPOA etc,
The line is just bridged from the Telco, (it's a new one on me to) there arent even any usernames or passwords."
This is coming from the guy we're setting it up for...
Jon
A VPN tunnel if thats what you are after will be done via IP address usually, so on both of your routers, you choose the same type of VPN tunnel (if it's going to be a constant connection), point it at each others IP address along with the security credentials and away you go (this is a very crude description of what you will need to do)
We use Draytek 2820 routers for our clients to make setup a lot easier at both ends
Ok you got me!
Jon
But the VPN end points will be the routers. It shouldn't matter what happens in between (as long as VPN traffic isn't blocked)
We use Draytek routers to support VPN and VOIP between 5 offices in the UK and Romania and they work very well indeed - the VPN stuff is a breeze with them.
Normally Site to Site VPNs are IPSEC which is an open standard supported by most SOHO firewalls. If you cannot afford (or do not wish to buy) new firewalls with IPSEC support, you can use Pfsense which is an open source firewall solution which supports IPSEC as well as OpenVPN.
You dont need to worry about the lack of PPPoA in .se as IPSEC/OpenVPN are higher level abstractions (OSI Layer 3). All the lower level stuff is completely transparent :)
