- 13 Jul 2006
- Hell!! \m/
TITLE CHANGE: OS to QoS please
Ok I am on Virgin Media 60Meg. On newsgroups I've had 3mB/s down MAX but in theory I can get 7.5mB/s. I am yet to try running more tests with SSL on other ports and VPN? Now I know nothing much of VPNs but I wanna learn more on networking - I've a Diamond account with Giganews.
Anyway first off - with VyperVPN ( Giganews) - I'd like to try out these VPNs, I have 2 I can use and my router has 2 servers and 2 clines its Merlin FW on ASUS RT66U. So:
Can someone advise me on QoS? Do I need 85/95% of my bandwidth incase my ISP do the work then it doesn't work so I set a limit and it does? is that right? anyway ATM I plan on:
Clean speed test
85-95% of my connection up/down
http 80 HIGHEST
https
Torrent LOWEST
NEWSGROUP LOW
I want video, movies that are streamed to be highest, gaming too, will the VPN just be 1 type of traffic even if the router handles it? Well basically any advise on QoS or any better setups
- I wanna have 1 for my main lot of traffic to secure t?
- I want one non-UK for other things that need non-UK IPs
- Can I have it were my mobile is on a WIFI or another IP and then connects to a VPN (either routers own or VVPN) and it becomes connected to my home network? say LAN over WAN (does Vyper do that or Router)?
- Is ebay.com and pw's safe on VPN?
- My routers own VPN server can I have it on too? to connect to home from outside but then it's sent to the other one??
Clean speed test
http 80 HIGHEST
https
Torrent LOWEST
NEWSGROUP LOW
