VR Cover for Oculus Go
16 Jul 2010
I've just bought a VR cover facial interface replacement for the Oculus Go. I was finding the existing interface tended to put a lot of pressure on my cheeks so I wanted to try something different.
https://uploadvr.com/oculus-go-gets-replacement-facial-interface-with-vr-cover/
I tried this out briefly last night, and it's much more comfortable than the existing interface, but there are a couple of issues:
Firstly it doesn't fit with the glasses spacer. If like me you wear glasses in the Go (and it's very comfortable with glasses) you'll have to leave out the spacer. I tried without the spacer and it seemed ok - my glasses did not touch the Go's lenses, though I would be happer if it worked with the spacer.
Secondly, if you have a 3D printed lens cover & controller holder, then this will no longer fit. This is somewhat annoying as I think the lens cover is a fantastic way to protect the Go's lenses when not in use.
I'll still be using the cover but I wish those two issues were solvable. Perhaps someone will design a slightly different lens cover that works with the VR cover.
