Not with that 1050 Ti card, you won't. I have a 1050 Ti 4Gb here, it's in my emulation machine, and it copes with multi-shader emulators quite well, but PC games are a bit hit and miss. The problem of 3 screens is the resolution, it will be too high for the 1050 to cope. In my Arcade 1-up emulation PC, the resolution of the screen is 1280x1024, and the 1050 Ti in there just about copes with a few PC arcade-type games. While Retroarch emulators using multiple CRT shaders, it copes rather well.
With VR, you would need to run at the headset's native resolution and refresh rate, and the card would need to keep that without losing fps - or you can suffer from lag, and lower fps - which can make a few VR users quite sick.
My Rift S has a single LCD display with a 2560x1440 resolution at 80Hz, a 1050 Ti would not be able to cope with such a high res and refresh rate in few, or any VR games. Even the older CV1 had a OLED display with 2160x1440 resolution and 90Hz refresh rate, and a 1050 Ti would still not cope with that.
Personally, I would look for a second-hand GTX 1070, if you have the money. I often see them on ebay for around £150 - £200.
