VR hub etc?
18 Dec 2008
Liverpool
Hi guys,
So I've got the Rift S but don't have a lot of space for keeping it out on display. Do you guys use or recommend a hub so am not having get to the back of my PC whenever I want to use it?
I use cable extensions with my Rift CV1, and it's a great way to avoid wear and tear on the PC ports, plus it's super easy to unplug and untwist the cable, which helps prolong the cable life (super important when CV1 cables are almost impossible to obtain now).
I printed a hub off and used cabled extensions - you can see it in this photo screwed to the underside of the shelf beside the lanyards.
