- 13 Jun 2016
Calling on the collective wisdom of OC for some help with a dedicated VR build. Overall, the aim is to go over-kill for the current generation of VR sets, but the PC would then also last through the next-generation HMDs. Budget is ~£2k to spend on the PC (with the monitor / Vive extra).
From a first pass through the Pro Gaming PC Configurator, I've drawn up the following list as a starting point:
Case: be quiet! Silent Base 800 Midi Tower Case - Black Window
Motherboard: Asus Z170-A Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Processor: Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - OEM
CPU Cooler: be quiet! Dark Rock 3 CPU Cooler
Memory: Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-21300C16 2666MHz Dual Channel Kit - Black (CMK16GX4M2A26
Solid State Drive: Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)
Mechanical Hard Drive: Seagate 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM001)
Optical Drive: OcUK Value Blu-ray / DVDRW combi SATA - OEM
Power Supply: Super Flower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black
Networking: TP-Link Archer AC600 Dual Band Wireless USB Adapter (Archer T2U)
For the Graphics Card, I was looking at the Gigabyte 1080 Xtreme Gaming (specifically with the Premium Pack with the front mounted HDMI & USB ports for a Vive) when that comes available (early July?).
So, what here is under / over-powered relative to each other? What would you swap in/out? Any other recommendations?
