Thanks mate,
I was trying a few things with my asus Maximus VIII Impact board and intel i7 6700K CPU with regards to the LLC thing, its kind of new to me although I have seen LLC mentioned several times in several places on the internet.
I have it clocked to 4.6, LLC at level 5 and voltage cpu voltage locked to 1.344 and after running
lots of RealBench_v2.44 (latest edition) benchmark and stress tests using that program it sailed through the tests.
I tried several LLC levels starting from level 1 upwards etc, and each time I changed the LLC level I would try a few Realbench benchmark tests and write down the scores I was getting and watch the core tempreatures etc.
I found the LLC 5 seemed to be the sweet point, level 6 and 7 actually started reducing the scores quite a bit and made a big increase in the cpu temps too, well at least I think it was LLC that was causing it,
lol
I am not one much for benchmarking just for the scores sake but its nice to see scores climb I guess, tempreatures in this room right now an ambient about 22c - 24c and the idle cpu temps are roughly between 25-26c to 29-30c on idle depending on what wepages I am looking at etc, benching and stressing though it gets up to about maybe occasionally touching mid 70's or at the most the odd time will touch high 70's but not constant obviously.
I got about 147187 result on Realbench benchmark test last I checked, I dont know if thats good, average or poor for this tiny little ITX build in this tiny little Node 304 case
, I have just a cheap little graphics card though, so I would assume that will keep the score down, I dont game, so I just stuck an EVGA GeForce GTX 750 Ti Superclocked card into it as there really isnt that much room, plus as I say, I don't game, so its an excellent little card in that respect indeed.
Node 304 Case >>
https://www.overclockers.co.uk/fractal-design-node-304-htpc-chassis-white-ca-024-fd.html
Maximus VIII Impact ITX board >>
https://www.overclockers.co.uk/asus...1151-ddr4-mini-itx-motherboard-mb-677-as.html
CPU >>
https://www.overclockers.co.uk/inte...ocket-lga1151-processor-retail-cp-581-in.html
Cooler >
http://www.corsair.com/en-gb/hydro-series-h80i-gt-high-performance-liquid-cpu-cooler
(I could only get one fan on the Radiator as there isnt enough room, but it seems fine like that, touch wood for luck, lol)
