VRMs overheating/faulty?
27 Dec 2012
I've notice the VRM's on my mobo or insanely hot (can't touch them for more than two seconds).
Could an overheating or fault be causing my cpu's vcore to drop when under load? Happens during BF3.
Do I need a new mobo?
Many Thanks
Zinnkio
CPU temps are fine btw.
Your CPU is throttling (only if you Mhz go down too, otherwise it's just Vdroop), it's nothing wrong with the board it's just they aren't designed to support such an overclock..
An what's causing your Vcore to drop under load is vdroop which is common in any overclock unless you LLC is set to high/ultra.
My advice:
  • Your Motherboard is fine
  • Turn down your overclock
  • Check LLC settings
  • Don't touch your VRM's :)
Clock speed comes down too. 800mhz - x4.0 multiplier, then goes back up after about 5 seconds. updated bios which said it would solve the problem, unfortunately it didn't. If this board isn't designed to support such an overclock should I purchase a new one? I was thinking of doing so anyway...
A Gigabyte 990fxa-UD3?
It seems your CPU is throttling a little bit then..
Gonna be honest, id rather turn it down (3.8ghz) until it doesn't throttle instead of spend £100+ on a motherboard which may be out of date soon, as were not sure where piledriver will work on the current socket/chipset.
That Gigabyte board - check it's rev 4 before buying, as rev 3 isn't any good.
Otherwise the £89 Asus 970 EVO is a good board, and fully supports the 8350 too.
@teppic - The board is rev 3 I believe. What's the difference between them both?
The rev 3 has inadequate VRM design, it's fixed in rev 4. Someone here was just posting that their 8320 won't run at stock speeds on a rev 3 - it's quite common.
These are the rules regarding signatures.
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
http://forums.overclockers.co.uk/faq.php?faq=vb_board_usage#faq_vb_memberlist_how
You need to get rid of the empty line, maybe try moving the quote to the bottom.
Turning down the clock hasn't done anything, problem persists. I've had this motherboard a long time, could it be that it's just giving up on me?
If you were thinking of upgrading the board anyway, it's worth a shot - especially as it'll give you SATA 3 etc. People regularly get 8320s up to 4.5GHz or higher on the EVO R2.0s.
Yea I'll have a look around. I liked the Gigabyte board because it was all black. (some OCD kicking in there) I also needed one with a USB3 header because of my case having two USB3 slots at the front. If you have any other suggestions I'll be happy to take them on board and then decide between them or the Asus EVO 2.0.
Thanks again
Does the Asus not have a USB3 header?
Have you asked ocuk if the UD3 is rev 4? If it's not, they may be able to get some from Gigabyte. The UD5 is fine, but it's a bit expensive.
These are all good boards for overclocking:
YOUR BASKET
1 x Gigabyte 990FXA-UD5 AMD 990FX (Socket AM3+) DDR3 Motherboard £141.98
1 x Gigabyte 990FXA-UD3 AMD 990FX (Socket AM3+) DDR3 Motherboard £113.99 <-- only rev 4
1 x Asus M5A99X EVO R2.0 AMD 990X (Socket AM3+) DDR3 ATX Motherboard £104.99
1 x Asus M5A97 EVO R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £89.99
Total : £462.95 (includes shipping : £10.00).
Thanks for the reply. I've asked ocUK about a rev 4 board of the UD3, and I'll see what they say about it. As for the others, I'll have a look at them also.
Thanks again.
I've been playing BF3 now for around and hour now with no lag spikes, vcore and clock drops. The room is pretty cold atm and my cpu hasn't gone above 45c whereas it gets to 53 normally. I'm still stuck to whether it's the Mobo or the CPU. It usually happens when the CPU gets to 53c but I've been up to 58c without issues which is what made me think it's something overheating on the mobo.
From this can anyone say whether it's the actual Mobo or CPU, Would be much appreciated
Zinnkio
