Vrrrrbbbbb (audio problem inside)
11 Mar 2012
North East
Hi all,
I have the most annoying audi issue, music on any player. It makes the vrrrbbb sort of stutter sound at random intervals. I know the files are fine.
So far I have
-Updated mobo audi drivers
- removed all mobo audio drivers and tried native W7
-Turned off effects in control panel under sound
-updated codecs
Still same issue I am running out of ideas and would rather not have to reinstall windows. I thought it was low internet connection on streamed radio at first so tried listening to some of my music and relaised its a pc issue.
Windows 7 64-bit, pc is in my sig.
Hope this is the right section!
Fixed
Anyone getting this issue after those steps run a latency checker.
Then systematically disable possible culprits in device manager.
I recently moved my system and the wifi signal is much poorer in this room, it was my wifi card, updated the drivers and it is fixed.
