Vsync with freesync or not?
19 May 2015
My 144hz Freesync AOC monitor arrives today but, when I am all setup with freesync enabled, do I also want to enable vsync for when my fps drops or increases outside of the freesync range, or do the 2 cancel each other out?
Just disable vsync. The latest AMD drivers have now a way of dealing with frame rates drop below the freesync range, it's called low frame rate compensation.
If you are getting higher than 144fps in games then raise the settings or else you can turn on the frame rate target control in the AMD settings.
