VTX 280x
12 Dec 2005
I'm getting a VTX 280x from the MM. I haven't heard much about these cards, I did some Googling but didn't really understand much of it.
Will it be a good card to go for? Will be upgrading from a 7850 2GB. Just not sure about the VTX thing, is it just the branding of the card? Won't be overclocking it.
Noticed the VTX cards are going so much cheaper on ebay than other brands. Around the £90 region..... Trying to figure out why this is.
Hmmm, think I might hold out for a better brand? Was going to pay £120 on the MM but for some reason the exact same card is going for around £80-£100 on an auction site.
VTX3D are still good. I also have an XFX 280X DD Black which is crossfired with the VTX3D card. The XFX card runs ~10C cooler than the VTX3D card.
New I paid 187 or so In jan when most 280x were 240 ish
Cooling is ok ,nice backplate. Manufacturer support is non , only retailer support if it breaks.
I ran 5 24/7 for months mining no issues.
Picked up a SAPPHIRE VAPOR-X R9 280X 3GB GDDR5 OC (UEFI) from the MM.
In the system specs of the card it says a 750W PSU is required. Mine is only a 500W OCZ.
I have a vtx 7970 x edition, and I wouldn't recommend it tbh. Elpida ram and it isn't a great clocker.
It's pure luck as to whether you get Elpida or Hynix RAM. The amount it will also overclock is pure luck. You may have just been unlucky getting a bad overclocking chip with Elpida RAM.
They overstate the PSU that you'll need, if you're worried about it you can buy a wattage meter to see what your PC is using. Then use that to decide if you need another PSU or not. If it uses ~400W at full load you should be ok. If it uses more i would consider upgrading it to something around 850W. That'll allow you to add a second card if you want to later down the line.
