Hi there
We sold out!
A 290 flashed to a 290X performs identical to a genuine 290X.
We still have these 290's flashed to 290X in stock:-
HIS Radeon R9 290 Pre-Flashed to R290X 4096MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included @ £383.99 inc VAT
nonl2br
<p align="left">
Pre-flashed by Overclockers UK Technicians using a voltage unlocked R290X BIOS unlocking the additional stream processors, giving a total of 2816 stream processors. Also voltage unlocked as well and with a full guarantee and warranty.<br>
<br>
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
</p>
<br />
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/6z-Z31pvRRE?version=3&hl=en_GB&rel=0"></param><param name="allowFullScreen" value="false"></param><param name="allowscriptaccess" value="always"></param>
<embed src="//www.youtube.com/v/6z-Z31pvRRE?version=3&hl=en_GB&rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="false"></embed></object>
</center>
<br />
<br />
<p align="left">
<h1>Specification</h1>
<b>Radeon R9 290 Pre-Flashed to R290X</b> <br />
- GPU: Hawaii Pro flashed to XT<br />
- Stream Processors: 2816 <br />
- Core Speed: 1000MHz <br />
- Memory Speed: 5000Mhz <br />
- Memory interface: 512-Bit <br />
- Memory capacity: 4096MB GDDR5 <br />
- Cooling: 2-Slot Blower Fan <br />
- PCI-Express X16 lane required <br />
- 750W or greater PSU required <br />
- Power Connectors: 8-pin + 6-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort <br />
- Warranty: 2yr
</p>
<p align="left">
<b>Features</b><br />
- Flashed to R290X <br />
- Unlocked Voltage <br />
- DirectX 11.2 Support <br />
- Open GL 4.2 Support <br />
- Dolby TrueHD and DTS-HD Master Audio support <br />
- Crossfire Support upto 4-way: Native software crossfire (No bridge required) <br />
- Gaming @ 4k Resolutions (UltraHD) <br />
- Synergy with next-gen game consoles (Mantle) <br />
- Graphics Core Next (GCN) architecture - optimized from previous generation products
</p>
Only £383.99 inc VAT.
ORDER NOW
OcUK Tech Labs EXPRESS - HIS Radeon R9 290 Pre-Flashed to R290X 4096MB Watercooled Graphics Card with BattleField 4 PC Game Included @ £479.99 inc VAT
nonl2br
<p align="left">
<br>
This card comes with a waterblock pre fitted and is ready to ship now. <br>
<br>
Never has a pre built watercooled card been such a complete package! All of this cooling power would be wasted without the addition of the worlds leading cooling paste, included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block. The remainder of the paste will be sent with the card for future applications.<br>
<br>
This card is hand assembled and tested in house by OcUK Technical Staff and is part of our new Tech Labs Express service. This means that the card is pre built and ready for you to order for immediate shipment.<br>
<br>
<br>
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.<br>
<br>
<br>
<p align="left">
- EKWB 290 Nickel Plexi Water Block - Pre fitted by experts <br />
- Warranty: 2yr
</p>
<p align="left">
</p>
Was [£499.99] Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
