** VTX3D R9 290 PRE-FLASHED TO R9 290X & VOLTAGE UNLOCKED!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Once again Overclockers UK leads the market by offering its customers the first Pre-flashed R9 290 for your convenience to R9 290X with voltage control, give you extra performance out of the box and improved overclocking ability*
We have sourced a batch of VTX3D R9 290's which unlock, at Overclockers we pre-flash these cards with a voltage unlocked R9 290X BIOS giving you the additional stream processors (2560 upto 2816) and voltage control upto 1.412mv for improved overclocking*
This is all done for you and fully guaranteed with a full 2yr warranty.
Here is a Heaven 3.0 benchmark to prove the cores are indeed unlocking:-
R9 290 @ 1000MHz Core / 5000MHz Memory
R9 290 pre-flashed to R9 290X @ 1000MHz Core / 5000MHz Memory
As you can see a clear improvement, depending on what game or benchmark you are running, you will see a 3-6% gain giving you full blown R9 290X performance levels. :)
You can buy the card here pre-flashed by our technicians and ready to go:-
VTX3D Radeon R9 290 Pre-Flashed to 290X, X-Edition 4096MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
Pre-flashed by Overclockers UK Technicians using a voltage unlocked R290X BIOS unlocking the additional stream processors, giving a total of 2816 stream processors. Also voltage unlocked as well and with a full guarantee and warranty.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290 Pre-Flashed to R290X
- GPU: Hawaii Pro flashed to XT
- Stream Processors: 2816
- Core Speed: 1000MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yy
Features:-
- Flashed to R290X
- Unlocked Voltage
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £359.99 inc VAT.
ORDER NOW
Most epic Mr Gibbo!!
What an amazing deal offered by OCUK, gives those with no bios flashing experience the opportunity to grab one, and offering the warranty cover too.
Excellent work, OCUK proves it looks after its customers!
This is an amazing offer dont think you will get the anywhere else still dont want a card with reference cooler my self perhaps overclockers could offer preflashed and custom heatsinks fitted but guess then the price would be too high
Not just that but now your not taking the gamble of hoping a card might unlock or not either. :)
Ordered, is tyhis much of an upgrade over my GTX680 2GB?
EDIT: Doh I have pulled out at the last page lol, my GTX680 does me. I must resist spending with Christmas around the corner. :)
So hold one, flashing the BIOS on a VTX 290 unlocks extra 256 shader cores similar to how people where buying the early 6950's and flashing them to 6970's?
