West said:50k for belts isnt it? 80k for chains?
hittman said:just got back from VW free visual check and they noted the following that needs doing with costs:
* Rear washer is leaking behind C pillar £58.09 inc
* Cambelt change is due £377.70 inc (this includes modified plastic waterpump)
* look into any problems with the coils £79.31 inc.
Also found out my car does have brake pad waer indicators so all my front brakes are fine. I'm assuming theres an indicator for the back as well? So total for the above is £515. ouch!
any advice?
any advice?
Randell Floyd said:What ever you do get hold of the metal waterpump, even the newer plastic ones are far too prone to failure. If a dealer say they can't supply one purchase one from a tuner or garage that can, likes of Jabba, Awesome GTI only won't fit plastic one's at all now.
Also check if they do replace the coils there not the ones from the major recall, as they would then be a free replacement.
chrisstevens said:Apparently some dealers are supplying waterpumps with metal impellers.
part no. 038121011CX
http://uk-mkivs.net/forums/thread/336024.aspx
hittman said:ok thanks. I'll do abit of digging and see. Regarding cam belts change etc, been told via vw its 40k or 4 years which ever is sooner but some of my m8's had it done at 60k. very confusing when to it but better to be safe than sorry later.
chrisstevens said:Some say 40k some say 60k. My two nearest dealers say 60k or every 4 years and then its checked every 20k after that.
It used to be 5 years and 80k if I remember rightly but after a "few" tensioner and waterpump failures VAG decided to lower the intervals.
http://www.briskoda.net/forums/gene...echless-pics/73866/?highlight=Polo+water+pumphittman said:I asked regarding the waterpump and the woman said it was a modified plastic one and not a metal one. She said they were aware of the problems hence the modified one. the price above does not include a metal thing I don't think. how much does a metal one cost?
regarding the coils, I asked them to look at it as I have random loss of power at high speeds. for example, on the motorway, cruising then suddenly I lose power as the rev counter goes down for 1 second and returns to normal. Quite scary doing 70mph on the motorway when it happens.
