I've had an Air Bag fault on my on board computer for a while now and I went to my local VW garage to ask how much it would be to just find out what the problem is. I was told £45-£90
Not wanting to spend that much I found a VW/Audi fault diagnostic tool on ebay for just £27 delivered from america
I've just tried it out and it found two faults;
1. 00532 - Transmission control module relay-supply voltage (B+) Malfunction Low Battey or Bad Ground
2. 00588 - Air bag Ignition Circuit Driver Side N95
Can anyone enlighten me as to whether or not its a good idea to clear the code, how much it would cost to repair these faults and if it's possible for me to do it myself?
The manual gives a warning about clearing codes as it "not only deletes codes frm the vehicles onboard computer, but also 'Freeze Frame' data and manufacturer specific enhanced data. This has put me off just clearing the code
Any advice appreciated
