Nextdoors Polo (P plate - Mk4) has developed a weird lighting fault last night.
It will switch on the sidelights, but not dipped or main beam.
If you indicate whilst the lights are off it's fine, but the main beam indicator lamp comes on faintly on the dash
If you put the hazards on the main beam indicator lamp also comes on.
If you indicate with the sidelights on you get alternate flashing of sidelights and indicators.
I've tried unplugging the headlight switch/hazard switch/indicator stalk in an attempt to do a quick fault find but no joy. Every combination gives seemingly random faults.
One thing I've noticed is that the Hazard Switch seems to play a big part in the lighting - it has 8 or so connections at the back - so I've asked her son who works at a scrappy to borrow a few spare switches from work.
Any VW perverts know of any "known issues" with these things?
