Service: means subject to the exclusions contained in clause 4, all the parts and labour charges needed
to comply with the Service Schedules, including all engine oils
(b) Service Plan - Additional Exclusions
xiv) All non-standard service work.(xv) Cambelt and drive belt.(xvi) Air conditioning.(xvii) Drive train gearbox/Transmission service.(xviii) BEVs – Battery Electrical Vehicles
What is covered?
All electrical and mechanical factory-fitted components are covered against electrical or mechanical
failure unless listed in the “What is not covered?” section.
Replacement parts and labour will be paid for with the following exceptions:
– Routine servicing (all parts replaced associated with routine servicing are excluded)
– All bodywork, glass (including heated) and seals
– Wear and perishable items as follows:
All adjustments, cambelt timing, diesel timing or cleaning
– Batteries
– Brake frictional material
– Bulbs and fuses
– Clutch frictional material
– Coolant pipes and hoses
– CV boot gaiters
– Exhaust systems including diesel particulate filters (although catalytic converters are covered for
internal failure only)
– Non-manufacturer’s original parts or second hand parts
– Tyres and wheels
Unencased drive belts
– Upholstery, interior and exterior trims
– Washer pipes and vacuum hoses
– Wiper blades, arms and washer jets
– Wiring and connections (including HT leads and aerial coaxial cables)
