- 9 Dec 2008
I'm trying out Visual Web Developer. I brought some pics to help explain what exactly I was doing (becuz VWD allows for so many different kinds of projects). I started a new aspx web page:
VWD automtically adds a pretty Tabbed default layout and with other automatically generated pages ready to be filled out:
So as you can see there are Tabs by default for the Home page and the About page. Then I decided to add a NEW aspx page to the project and then discovered that there is NO file (like a "Layout" file) amongst the project files that defines the Tab menu and it's contents.
What's going on? Earlier on I tried out starting a new razor cshtml web page. With that one there WAS a "sitelayout" file in which you can declare the contents of the Tabs menu. Why is there NO layout file with the aspx project? With that one there is no way that I can find to edit/add-to the Tabs.
Thanks
Thanks
