VX2025wm offset slightly on stand?
9 Sep 2006
Hi guys,
I would just like some VX2025wm owners to help me please with something.
Have any of you noticed the following?
Imagine you have the stand of the monitor flush against something straight like a table edge or something, the monitor screen itself does not look flush with the stand and looks like it has been rotated slightly to the left, hence the right hand side of the screen being slightly closer to the user than the left hand side.
To compensate, you have to swivel the base to the right so that the screen looks straight and more flush, but the down side is the base is then pointing to the right instead of the screen to the left!
I read a post on another forum where someone mentioned that they measured the distance from the edge of the stand to the actual display and found it was 11cm on the left hand side and 11.5cm on the right hand side, so slightly offset to the left.
He also said his friend noticed the same thing which his one and someone on another forum also noticed it.
Thanks guys,
Kallum
