i recently upgraded my w/c loop so I could give my phase unit a bit of a rest (noise, power consumption etc.)
The new loop is
cpu - storm
chipset - mcw30
gpu - mcw60 with ramsinks
pump - mcp600
rad 1 - mcr320 + 2x loons (3 won't fit until I change my mobo)
rad 2 - unknown 120.1 + loon
tubing - 1/2" tygon with jubiliee clips
1/2" ek barbs
The fans in the top pull air in through the 320 and I am pushing air out of the rear through the 120
Which was cobbled together from my exitsing loop and some second hand bits.
pics
http://picasaweb.google.com/george.gornall/NewMonitorAndWatercooling?feat=directlink#
My ageing rig is
e6400
asus p5n-e sli
8800gt 512
My cpu temps at 1.5v/3.4ghz are around 65 on die but the cores are reporting up to 80ish under load with everest or realtemp which seems high to me.
The GPU and northbridge are reporting 40ish and the gpu increases by around 8 degrees under load. Room temp is 20ish and internal case temp 23ish with an external digital themometer.
The cpu block is hot around the edges.
So why the high temps?
Is the pump not pushing enough water? Visually when filling it seemed to be pushing pretty quickly and there is turbulance in the res.
or is the storm block not really good enough for dual core cpu's?
I was worried about the contact between the cpu and block so I lapped the cpu but it made little difference
There are no kinks or restriction that I can see
Thanks for the help
The new loop is
cpu - storm
chipset - mcw30
pump - mcp600
1/2" ek barbs
pics
My ageing rig is
e6400
asus p5n-e sli
8800gt 512
Thanks for the help
