Guys,
I have my CPU W/C'd (i7 2600k) via a 240 rad with 2 silverstone penetrators doing the cooling on said rad.
I also have 5.25" bay res, I am however looking at adding a 7970 into the loop with the addition of an additional 120 rad.
my questions being should i ditch the silverstones and opt for sythe gentle typhoons? if so which rpm is best? or if there are even better fans available?
could you also reccomend a fan controller
would a 240 with an additional 120 suffice for cooling the cpu and the gpu?
is it worth having 4 fans on the 240 (two above and two below?)
