I'm in the process of researching for a custom cooling rig.
I want to use GTX 460/470 and will probably go SLi.(These will be O/C too)
CPU will be i5 with the highest O/C I can safely get.
All will be water cooled (Ram and Mobo too eventually) but how much rad space will I need?
I was thinking 2x120.2 (Res>pump>120.2>CPU>120.2>GPU) but there is so much conflicting evidence.
So, I'd like to throw a few questions out so I can get some idea of how much radiator area I will need to make a good job of the overclock.
Noise isn't a high priority, performance is! I'm looking for a good solid o/c, I don't expect chilled cooling performance obviously but I'm sure you understand what I'm looking towards.
1. How much rad area do I need to get them to a good O/C? (will 2x120.2 do? or should I look for more?)
2. Will push pull have a significant effect on cooling if installed on the rads? (vs just a single push or pull config) or is more rad area more effective?
3. What is the most efficient radiator combination? Should I use two loops rather than one?
Thanks
Scotty
Thanks
Scotty
