W/C Prodigy - Fan Controller
14 Jun 2012
Halstead, Essex
I've got a Bitfenix Prodigy that i've watercooled witha 200mm rad in front and 240 in the top.
I'm looking for a decent fan controller that i can use which doesn't sit in the optical bay. As there is no room for one. I was using an old corsair link, but basically it doesn't work very well. The motherboard only had 2 fan headers and i have 2 pwm fans and 2 3 pin fans.
Ideas?
Did you happen to watch ghostbusters 2 right before ya ordered that coolant by any chance? :)
Do you guys find that you need to have CAM running for the fans to change speed? I have mine set up with a fan curve that depends on GPU temp but if I close CAM it just keeps the speed constant.
Lol nah that's a pc i made for my other half so I let her pick a case and what fluid.
I haven't tried it without cam. just set it to run minimized in tray and let it do it's own thing. Took the cover off and noticed fans changing speed.
