as an ex mechanic of 7 years VAG experiance i had a thought about watercooling
has anyone ever thought of super glueing the coolant pipes to the blocks to have zero chance of leakage in that area ?
then a cable tie would be ample as well (less hassle than doing up jubilee clips etc. methinks)
to remove you can stanley knife off, then sand away the residue super glue with varying grades of sand paper to bring out/inlets back to new
this is what mechanics sometimes do on car coolant hoses using araldyte or something so as to minimise risk of coolant hoses blowing off
what are your thoughts?
