OK so I'm currently using a standard air cooler on my 2500k CPU but have in the past had a W/C system setup - however due to moving the PC quite a bit air is just simpler.
I've decided to do a rebuild/mod of my water cooling during the summer and have started to think about what to do. I'm currently planning on modding my v2000 with bottom cut outs and a window.
The reason for the bottom cut out aren't as simple as an air intake or exhaust, but rather to give me more space in the bottom. I'm thinking of going with two Black Ice Sr-1 420 Rads in the bottom with push pull config with the fans. However the Fans plus the Rads are too thick for the bottom of the case so by having the cut out it will allow me to push the Rads further apart so the outside fans end up outside the case. I then intend on using some mesh to bend around the fans so they are covered - buts that another issue.
My questions are:
1: Having 2 of the radiators plus CPU block and GPU block, what's the best way to have the system setup. Dual loop or single loop? If single loop would my current 10w DCC pump be sufficient or will I have to go for a 18w one.
2: If I end up with two pumps would putting them in series or by getting a dual pump top be best. Would the fact I would have 10w and 18w pumps impact on doing either of the two options?
My questions are:
